RON'S WEB SITE
Date:  7-8-2010
Number of Hours:  4.00
Brief Description:  Installed MT prop brush....
...Installed MT prop brush....We fit the hand milled brush fabricated from 1X2 T6061 alum. bar to the mounting bracket by making a pattern and scribing around the bracket when held in place with a C clamp. We used spacers to get the bracket in position and to insure that the brushes are centered on the slip rings. The mounting holes were drilled with a reamer on the drill press. The mounting blocks were reamed out and the gap was set at .040 using a spacer. The manual called for .030-.050 hence the mid mark was chosen. The brush block was secured with AN3-21 bolts and nyloc nuts in accordance with the MT manual.
Adel clamp & alignment marks
torque seal for crosscheck
Protective sponges
Protective sponges
