RON'S WEB SITE
Date:  12-12-2011
Number of Hours:  1.50
Brief Description:  Calibrating fuel stick...
...Calibrating fuel stick...Used a locking clecoe clamp to drain R fuel tank and added fuel measuring with a modified HF ruler. You slide the plastic down into tank until seeing the ripple when it touches the fuel level and read the inches of fuel at the top so you can compare to your measured fuel scale.
Cut so it will fit into tank
Old and new
Old and new
