Brief Description: Redid D-subs for elev. trim & ran wires forward...
...I discovered I had improperly crimped the female D-subs so I redid them properly. It would be good to fit them together prior to crimping to insure proper fit. I noticed the female fitting was not seating properly with the male and had crimped the females backwards. I ran the cable thru the HS and attached a adel clamp to secure it before threading it forward. Connected D-sub assembly and secured access panel. Attached ECM ground to front sea of tabs after crimping with barrel type environmental seal using heat gun to finish. Also arranged instruments the old fashioned way with cutouts and tape.
