Brief Description: Mounted nosewheel, main gear wheel...
...Mounted WD-631 to nose strut top, aligned for NAS5-17A bolt which I ordered, mounted nose tire assembly and compression springs on bottom, and finger tightened retaining nut. Mounted R wheel assembly to R gear leg after sanding axle for clearance for weldment and driving into position and bolting. Same with L gear leg ,but wheel isn't yet properly aligned on axel for VA-106 retaining nut.
