Brief Description: Replaced stripped AN5-21A bolt in R gear...
....Used dremmel to continue cutting nut in second place and removed stripped nut. Bolt needed replacement and used shorter AN5-20A with one AN960-516 washer and torqued nut for both R and L gear weldment bolts (used 2 washers on L) to 130 in/lbs.
