Brief Description: Installed cotter pin in NG fork retention nut...
...After burning up four 1/8" drill bits attempting to drill thru the other side of the axle I doiscovered it had slipped into reverse after the first hole. A new bit and forward made quick work of the other side and the cotter pin slipped right thru easily. Also ran more wire thru the wing.
