RON'S WEB SITE
RV-6A QB
Wheels/tires/gear
8-10-2011
Installed drilled bolts/wheel pant fitting...
...Installed drilled bolts/wheel pant fitting...Paul drilled heads of AN4-5A bolts and saftey wired to cotter pin securing gear nut per plans. I matched L wheel pant gear cutout on R wheelpant and drilled/filed away for mounting
Paul installing wired bolts
Copying the other
Time saving
RV-6A QB Home
3742
A/C Hardware & Supplies
Ailerons
Brakes
238
162
fiberglass
92
208
166
Flaps
Flight controls
63
153
Flight controls
71
175
Fuel tanks/lines
Fuel tanks/lines
203
Hardware
Insturment Panel
115
279
149
Lycoming IO360
MT propeller
Painting preparation
Paperwork
Parts fabrication
Polishing
Rudder/Brakes
63
153
Rudder/Brakes
Shipping
Subaru Engine
Subaru engine
57
117
Systems
Trim tab
121
238
Trim tab
Weight & Balance
Wheels/tires/gear
43
90
Wheels/tires/gear
277
Wiring
71
175
Wiring
43
90
