Brief Description: Fitting NG wheelpant to tire...
...Fitting NG wheelpant to tire...Removed NG fairing and removed bottom area to allow more clearance when the nosewheel casters in turns. Bent mounting pin for better alignment into adjustable clamp. Removed more area for tire to spin freely. Removed front tire and greased bearings and installed attachment brackets. Expanded holes with unibits for access for 9/16 socket to loosen bolts for wheelpant removal.
