...Correctly mounted wheelpant brackets...Raised R main gear and placed correct bracket on wheel assembly. When I looked at the bracket I removed from the gear, it was labeled for the L. Attention to detail as they used to say in flight training. The other mount was drilled and K1000-8 nutplates installed before placing it on the R wheel. The brakes were safety wired.
