Brief Description: Drilled L main axle for 1/8 cotter pin...
...Drilled L main axle for 1/8 cotter pin...This time I started with a titanium 5/64 sharp drill bit and drilled thru the axle after punching thru the axle nut hole. This way you can remove the nut before drilling to verify the position before drilling. I always place tape over the rims of the wheels to protect them where contact can be made with the punch, hammer or drill or pliers when installing the cotter pin.
