RON'S WEB SITE
Date:  5-1-2008
Number of Hours:  4.00
Brief Description:  Drilled sides & riveted bottom cowl...
...Continued removing, filing and fitting bottom cowl. Drew alignment marks on each side so alignment will be correct for proper fit with top cowl removed. Riveted bottom hinges to cowl. Backdrilled side hinges using angle drill attachment while holding pressure to keep correct alignment.
L side hinge backdrilled
R side aligned & drilled
