RON'S WEB SITE
Date:  5-13-2008
Brief Description:  Drilled top R cowl hinge using hole finder...
....Drilled top R piano hinge with top cowl installed and used hole finder in each hole starting from front and moving aft. It turned out well. The R distributer wires are touching the cowl but the consensus is that it will not be a problem.
