Brief Description: Tested aeroflash units & discovered rework plan...
...Tested aeroflash units for proper operation. Drilled thru wing spar web area & installed grommets on each side of web and ran strobe/nav-pos/taxi light wires into cabin thru another hole drilled in the side of the fuselage ahead of the spar. Did same with R side for strobe/wing/pos-nav wires.
