Brief Description: Eng GRD bolt secured, wired ECU temp sensor...
...Routed ECU temp sensor and attached split loom for protection and secured with tie wraps. R ENG GRD bolt secured with lock washer and threadlocker blue. Cut and tagged unused Starter wire in engine compartment. Panel reinstalled to route wires . Wigwag wires #16 fabricated , labeled and ready for the ends from the 6 switch positions to be attached. Used bench power source to verify wire labels and watch the lights operate. Throttle lubed which has removed the sticking problem with the friction applied.In labeling the wires, I put where each wire goes to help remember if later troubleshooting is required.
