Brief Description: Glove box GRD, Batt hold downs taped...
...Taped both batt hold downs to prevent accidental contact with tools & pos. terminal. Moving wires to newly drilled side holes since they might contact subpanel behind and short out. Most of the fat wires go out the rear, thru a rubber grommet and out thru the firewall to connect to the batteries. Ran #12 Grd wire from case of accessory plug to glove box Grd. Tested charger thru Batt select and both batteries charge thru accessory plug in. Tested all ext. lights, flaps.
