Brief Description: Completing GTX-327 transponder/EFIS set up...
...Completing GTX-327 transponder/EFIS set up...Discovered shielded wire was installed in B connector instead of A. Installed female D-sub and relocated and programmed with help of Mark at GRT. It works. Did some set up for EFIS also. Left B connector off since I do not have a EFIS warning light and all other connectors are for "Future expansion".Place red electrical tape on L flap for position indicator from a glance from the cockpit.
