Brief Description: Repaired R Nav GRD, vac line,tested A/P...
...Repaired R Nav GRD, vac line,tested A/P...R Nav light GRD was not making good contact with outer shell. Cleaned & tested. Tested A/P and appears to operate properly including stick release button. Used a dremmel and shortened the shafts for the panel light knobs so that they are nearly flush with the panel to preclude bumping or breaking them. Replaced the vacuum lines from the EEIS MAP box to the PLEX box with the reinforced tubing and secured with tie wraps. Attached R control stick with removeable pin and added stick grip.
