Brief Description: Drilled L nylon aft canopy block...
...Drilled L nylon aft canopy block...Used a 12" 040 drill aligned with latch pin on canopy frame as guide for drilling the 23 deg. down and 5 deg. in hole, enlarged to 030, then 3/16" and finally 1/4 inch and it turned out well. Used 3/8" drill to make guide hole into entrance.
