RON'S WEB SITE
Date:  1-11-2006
Number of Hours:  4.00
Brief Description:  Drilling C-660 L side skirt/C-759 to plexi...
...Drilling C-660 L side skirt/C-759 to plexi...Called Van's for direction. Used R piece turned upside down and drilled to side canopy frame. Took C-759 inner plexi piece and match drilled the first four holes to already drilled C-660 after aligning top edges. Then reinstalled both pieces on canopy and drilled through C-759 using C-660 as guide. With Roger in cockpit we drilled through plexi. using the C-660 as guide into the top of C-759.
