Brief Description: Build up in front of windscreen...
...Build up in front of windscreen...Mixed 2 strokes of West 205 epoxy with hardened, black pigment and cotton flox and spread in front of windscreen after taping area with Scotch tape. Do not use a cheap subsitute or you'll spend hours regretting it while trying to remove it. Used a fine marker to outsine a one inch mark on alum. and windscreen. Added a retaining tab on each side to support edge of windscreen and used a roundhead nut since it was inside panel overhang.
