Brief Description: Rivet both side rails with CS4-4...
...Drilled out MK-319-BS rivets as they did not hold in 30 hole. It required 7/64 drill, but the instructions did not mention it, only their catalog that sells the rivets which frankly is not mentioned as required reading. Used CS4-4 which are slightly heavier, but stronger also. Remade arrow shaped lift handle for pilot side and riveted in place at rear of canopy side skirt.
