...Installed MT prop....Installed 5 regular flange bearings and short flange bearing in #1 slot and installed prop on hub sliding the bolts thru the holes, adding washer and nyloc. Gave ait a farm tractor tightening. The factory provided bruxh mount does not fit properly. It will be necessary to fabricate one.
