...Installed (2)F699...Primed Both F699; drilled thru stringers for 3/16 bolts and installed. Used spike to make imprint for 3/16 hole for wing spar on back of F696 and aligned for installation with spike. Moved R rudder stop higher on fuselage for alignment with opposite side and better contact.
