Brief Description: Ordered shockmounts and NPG + from Wickes...
...Another order to Wickes for shock mounts to use to install the brainbox for access above PAX rudder pedals along with some NPG+ for the radiator to raise the boiling point and lower the psi cap to be used from 20-25lbs to 7 lbs.
