Brief Description: Cut EFIS hole,planning for next cut...
...Used new air driven saw to cut part of EFIS opening but didn't dare try to stay on the line as it is a little difficult to be precise enough. Had to do a lot of work with Vixen file and reg. files to finish. Am not quite able to put airspeed and alt. on either side of EFIS. Wish I had not centered radio stack as even an inch or two right of CL would have been sufficient. Am going to make this work. The alt/airspeed will go below and if I have to rework EXPBUS mounting for clearance of pitot/static lines, so be it. Will see if EXPBUS needs relocating or re-orienting after airspeed and alt. are installed.
