Brief Description: Cut opening in panel for glove box...
...Finished trimming & filing sub panel for alignment of glove box so panel doesn't bind on R side. Used guide which I clecoed to panel and drew lines for cutting and placed masking tape for cut. Also used an aluminum scribe to scratch along edge for cut with portable dremmel cutting disk. Drilled corners, held breath, and it went slowly, but favorable results. Edges need more filing
