RON'S WEB SITE
Date:  6-3-2009
Brief Description:  Ran manifold line to engine & drilled ignition key
...Ran manifold tubing forward from GRT MAP box thru firewall exit. Drilled hole to install keyed ignition switch. Ordered electrical circuit breakers and parts from Wicks. I may return some of the non Klixon CB if they aren't needed.
Can I have the keys Grandpa?
