Brief Description: Fabricated dimmer bracket, drilled for dimmer...
...Fabricated mounting bracket for dual channel light dimmer. It is mounted on glove box where if the panel is pulled out, it'll go along for the ride. Also mounted fuel relay on bracket. Labeled back of panel for easier working and wiring environment. Installed more switches and light dimmer between the row of light switches.
