Brief Description: Protek rewired, wires connected to Main Bus...
...Rewired Protek Bus MGR with #8 wires based on potential loads of about 40 amps. Connected Protek Main Bus feed to Main Bus Bar using #8 wire. Used #10 wire to connect Main Bus Main Bus. #2 Batt connected to Keep Alive Bus on Bus tray. Connected ALT feed from Protek using #8 wire to neg. term of VA-1A (volt/amps). Battery charger selector switch for charging either BAT connected to Protek BUS MGR. More Insulating coating added to IGN switch wires to stiffen area. Wires are being routed across back of panel for ultimate tying.
