Brief Description: Wired clock, VA-1A, Avionics bus switch...
...Wired the clock to the keep alive circuit and ran a jumper from the batt to watch it run, ran a wire to the av.bus switch and back to the fuse and wired the volt/amp meter to the fuse block. wired the VA-1A (volt/amp) meter to the fuse block & grounded to glove box GRD. Tie wrapped some of the main bus wires running across panel. ordered supplies from Steinair.
