Brief Description: EIS fired up, tested fuel pumps, not yet...
...We hooked up both batts and turned on the Master key and set the EIS CB and it worked. Neither fuel pump would operate however. Used the factory provided numbers and the 29.r is MAP of 29.92 adjusted for field elev. of 541'.
