...Flap wiring completed and put crossover wires with Red (flaps up) wire in #6 blue connector and black (flaps down) wire in #6 blue with opposite crossover wire. Also used permanent mnarker to color code flap switch for maint. ease. Soldered 10k ohm resistor in red/white EFIS clock power and attached to Keep Alive circuit. Put EFIS/AHARS power wires together in one red connector and attached to top side of EFIS CB. the diagram for wiring this is in section 5 in the RV-6A QB manual from Vans. Installed flap switch in panel and tested.
