Brief Description: Assembling wiring to light dimmer...
...Put female Dsub pins on both dimmer pot wires and installed in pins 11 & 13. Installed Grd pin in 4. Installed volt amp brown & white wire in output pin 8. Spliced AOA ground into Icom Grd using heat gun and shrink wrap solder joint. LED GRD to mounting screw for Elevator Trim on rear side of instrument panel.
