...Rewiring fuel relay, firewall passthru installed.. ...David Cox had made a new wiring harness using heavy, longer wires. They were crimped with a GM style connector and soldered and heat shrinked. This will allow access to the relay with ease for maintenance purposes. ested unit and main pumop only. Called Protek bus and he will check and resolder connector jopints. It is curerrently operational with spray in connectors and pressure applied on connector. Covered MT wires/coil power wires with wrap and secured. Installed firewall passthru for MT prop.
