Brief Description: Drilled mounting holes for 31/8" SDS CRT...
...Drilled mounting holes for 31/8" SDS CRT and then had to file the bottom 2 to get the proper fit for the screws. Filed inside of CRT hole also. Drilled out unneeded nutplates on subpanel and installed new WB (wideband) sensor in exhaust pipe.
