Brief Description: Repositioned plane on adjustable sawhorse...
...Lowered tail of plane to raise the nose high enough to place the sawhorse under front and then placed a stand under tail to help lift the weight of the gear off the floor so gear weldment spar bolts can be tightened and torqued. Inserted more bolts through spars/gear weldments.
