Brief Description: Tested fuel tank ops, prosealed lines...
...Dave safety wired both fuel cover plate fuel inlets to anti rotation bracket. We prosealed under bracket and riveted both anti-rotation brackets to fuel plates. Both fuel gages worked properly as the float was raised and lowered. We hooked small jumper wires to a power source for checking. Prosealed fuel return line inside tank where it extends into the second bay of the tank and prosealed under 822 fitting.
