Brief Description: Mounted Subaru engine to firewall....
...Once the main gear were mounted, we drilled the top R hole to 3/8 and hoisted engine threading bolt thru mount and then we drilled the upper L and bolted. Next the bottom R hole and then bottom L and both bolted. The gear leg mounts were drilled and bolted . Praise the Lord!
