Brief Description: Plumbed coolant lines and filled with fluid...
...Plumbed coolant lines and filled with fluid...Coolant lines were cut to proper length and secured with Oetiler clamps. RV Coolant was added that absorbs water and after a hoped for soon to be engine run, this coolant will be drained and replaced with NPG+, a non water based coolant with an extremely high boiling point that allows a lower pressurized, or even non pressurized system. I installed a 7 psi cap.
