Brief Description: Fabricating shock mount for ECM...
...Did some trimming on attachment brackets for lightening. Used pop rivets to install to case of ECM. Fabricated attachment brackets of Z alum. and lightened brackets. Drilled for 2 shock mounts and installed using enough washers to tension nuts when torqued.
