...We torqued the aft spar wing bolts and installed cotter pins. We torqued the fuselage sides of the gear weldment #4 screws and marked with torque seal. I removed the R wing tank to gain access to the fuel return lines and removed the torn rubber gasket from the fuselage exit hole to the tank. Installed 45 degree fitting for 5/16 fuel line return.
