Brief Description: New plan for wing wires forward...
...I discovered that is will be possible to route the wing wires forward through under the wing spar, through the gear fairing, forward to a yet to be drilled hole into the interior behind the front fuel tank attachment spar. This will require less drilling under the seatpans and a more direct path to the instrument panel.
