...Continued removing, filing and fitting bottom cowl. Drew alignment marks on each side so alignment will be correct for proper fit with top cowl removed. Riveted bottom hinges to cowl. Backdrilled side hinges using angle drill attachment while holding pressure to keep correct alignment.
