Brief Description: Riveted top R piano hinge & fitted L radiator...
...Riveted top R piano hinge to cowl. Installed L radiator shroud and began filing corners where there was interference with the cowl inlet. It took quite a bit of filing on the lower L corner and about as much on the R side. I also filed some off the cowl inlet. It looks good and next will be the R which cannot be filed as the Subaru air inlet & filter is installed in the bottom of the shroud and it cannot be altered.
