....Used 230/320 wet dry sand paper to spend the afternoon communing with my cowling. Each batch of Icing Glaze i makes can only be worked 3 or 4 minutes so I make haste with the rubber squeege applying it and trying to leave none on the cowl. As you can see fronm photo one, I don't do well. You run it across the cowl and it fills the pinholes in the honeycomb area. After two coats, I primed with a filler which reveals more pinholes not yet filled, but thank the good Lord, there are less.
