Brief Description: Hung engine hoist from I-beam, plane off gear...
...Drilled 1/4 inch hole in I -beam and modified bracket with a longer bolt and alum. spaces to support engine hoist hook. Used cargo strap around engine bracket to raise airplane and support front with Pete Field's modified sawhorse. Removed front windscreen which was held on with clecoes.
