RON'S WEB SITE
RV-6A QB
Cut transponder opening & attached supports...
....Cut opening for GTX-327 using drill & dremmel cut off wheel. Filed to fit. Put angle alum strips behind panel, drilled and clecoed to panel. Drilled 2 holes & tapped for #6 screws on each side. Drilled and clecoed EXPBUS brackets to sub panel.
It is a start
Lookin better
RV-6A QB Home
3742
A/C Hardware & Supplies
Ailerons
Brakes
238
162
fiberglass
92
208
166
Flaps
Flight controls
63
153
Flight controls
71
175
Fuel tanks/lines
Fuel tanks/lines
203
Hardware
Insturment Panel
115
279
149
Lycoming IO360
MT propeller
Painting preparation
Paperwork
Parts fabrication
Polishing
Rudder/Brakes
63
153
Rudder/Brakes
Shipping
Subaru Engine
Subaru engine
57
117
Systems
Trim tab
121
238
Trim tab
Weight & Balance
Wheels/tires/gear
43
90
Wheels/tires/gear
277
Wiring
71
175
Wiring
43
90
