Brief Description: Received DD Gen III transmission, wiring advice...
...David Domeier delivered his GenIII reduction drive and flywheel which I will install at a later date. We did some panel planning and I have been implored to finish cutting the panel so that true wiring can begin. I did another hour of polishing and finished the HS and VS R side. Wired fuel pump switch so that mid position is both puimps ON, up is Main and down in Aux.
