Brief Description: Tied & routed L wing wires into panel...
...Paul tied the wing wires and l fuel sender wire i had fabricated in thru the grommet just in front of the L wing spar and using nylon sticky clamps and loose tie wraps, routed the wires to the area behind the panel. He used flat nylon wrap and tied it about every 4 inches to make a nice protected bundle. he also used some plastic tubling in the area of the rudder cable.
