...Drilled 3/8 hole for snap bushing for OAT probe under L HS in panel that is removeable. Also fabricated a bracket for the ECU connectors in the vicinity of the alternator belt. In the event of a belt failure and departure, nothing critical to engine operation can be in line with possible failure path. We may install an attachment to aid in confining the reach of the belt.
